Orbi WiFi 7 RBE973
Reply
Orbi Satelit loosing connection - Ethernet Backhaul connected
DNielsen
Just got a RBR750 and RBS750. The RBR in the main house works fine. But I seems to have issues with the RBS750, which is in the workshop.
They are backhaul connected via ethernet cable.
From time to time, it just drops the connection (Every 10-15 minutes). I'm perfectly connected to the sattelite (which I can ping) but I cannot ping the main router, while its lost:
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
But no problem pinging the satelite:
Reply from 192.168.1.4: bytes=32 time=2ms TTL=64
Reply from 192.168.1.4: bytes=32 time=10ms TTL=64
Both computers does it, the desktop where I got a ASUS AX58BT WiFi 6 card, and my laptop; MSI with Intel Wireless card.
The app says there is connection between the router and satelitte.
The ethernet cable works without any flaws with other routers.
Any ideas? What am I doing wrong?
Message 1 of 9
Accepted Solutions
Guru
Re: Orbi Satelit loosing connection - Ethernet Backhaul connected
what version of the firmware is the router/satellite on?
there's a beta version that just released that had a lot of fixes.
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/New-RBR750-RBS750-Firmware-Version-v...
Message 2 of 9
All Replies
Guru
Message 2 of 9
Guru
Are the RBS directly connected to the RBR or is there a LAN switch in betwen?
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Message 3 of 9
DNielsen
Directly, no switch in between.
Message 4 of 9
DNielsen
They where on the latest stable version. Just applied the Beta firmware to see if that fixes some of the issues 🙂
Message 5 of 9
DNielsen
So far, a couple of hours in, and haven't seen a dropout since, fantastic, thanks! 🙂
Message 6 of 9
Guru
Just curious, did you power cycle the RBR and RBS after applying the v5 FW or was a reset performed and setup from scratch or just applied the FW and continued with out interrption?
Message 7 of 9
DNielsen
Applied to the satelite firstly and then router. Turned them off for 2 minutes, and started them up again. No reset needed 🙂
Message 8 of 9
Guru
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1214 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
