- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Wi-Fi 6 Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Am I also able to supplement with other Orbi (not Wi-Fi 6) satellites? Will it work, even though I give up some speed?
I have about 12k square feet across 3 levels. I had 7 Google Wi-Fi units and it worked fine but not taking advantage of our speed.
Thanks for the help!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Wi-Fi 6 Satellites
Satellites in the software are numbered sat_0 up to sat_7, so seems that this is the max number of possible connected Satellites in Orbi AX
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have added 2 x RBS-50s to my network that are hard-wired and they work great. They are fully controlled by the RBS-853 as they were in the past.
I believe that any additional RBS-50 class satellites must be hard wired as the wireless back haul is not yet compatible.
See the attached screenshot
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again, very much appreciate the response.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a question about syncing RBS50 to RBR850. I guess I have to press the button on each of the RBR850 and the RBS50 to make them work together. Is that through wireless signal at first? Or, can they be done just wired? Do I have to just plug them to the same network and they sync with each other?
I am asking this question since Chunk_M mentioned their back haul is not compatible with each other yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RBS50 won't work wireless. Factory reset the RBS50 then connect via wired. They will only work wired to the AX system at the moment. Hopefully NG will get them working wirelessly in a future FW update.
@luxiloid wrote:I have a question about syncing RBS50 to RBR850. I guess I have to press the button on each of the RBR850 and the RBS50 to make them work together. Is that through wireless signal at first? Or, can they be done just wired? Do I have to just plug them to the same network and they sync with each other?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your quick reply, FURRYe83!
Do they sync with each other automatically once you conncected them wired? Or, is there a manual process of pressing the button on the router and pressing the same button on the sattelite even when they are connected through wired network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The one time I tried with mine it auto synced. Connect the RBS wired and power it on. Give it about 5 minutes. Check the 850s Connected clients list. I should appear there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Video link https://youtu.be/xPVGv0IHVao
- Mark as New
- Bookmark
- Subscribe
- Permalink
