× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
Orbi and Panasonic Homehawk camera not connecting
Chief2019
Tutor
I recently installed a new orbi AX 4200 router.  When trying to connect my Panasonic Homehawk shelf cameras I can not connect and am told by the homehawk app that I need to diable the isolation setting.  Firmware version V3.2.16.22_1.4.9   Can someone tell me how to do that?  Thank you
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 10
Accepted Solutions
Chief2019
Tutor
Re: Orbi and Panasonic Homehawk camera not connecting
I finally got them to work after doing a 30 second unplug and plugback in and reset on the camera.  multiple tries later it worked.  Thank you for the help.
Message 9 of 10
All Replies
Guru
Orbi doesn't support nor have isolation setting.
Are these 2.4Ghz cameras that use a installation mobile app to install them?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 10
Chief2019
Tutor
They are dual band I think.  We use the Homehawk app to connect them. https://apps.apple.com/us/app/homehawk/id1324939168           https://shop.panasonic.com/home-and-office/connected-home/KX-HNC800B.html
Message 3 of 10
Guru
I would refer to the mfr support site and help on how to get them installed. Only item that seems to cause problems is that some IoT devices don't like single SSID wifi broadcasts from some wifi system. Like Orbi, it only broadcasts 1 SSID name for both 2.4 and 5Ghz. Some IoT mfr software only supports 2.4Ghz which in unfortunate as both 2.4 and 5Ghz are technially on the same network.
You might inquire of the Mfr about if there setup software needs the mobile device to be on 2.4Ghz only or can it be on either.
Message 4 of 10
Chief2019
Tutor
By mobile devie do you mean my ipad with the setup app or the camera I am trying to setup?
Message 5 of 10
Guru
Mobile device..the pad
Message 6 of 10
Chief2019
Tutor
I did not really get any place with the manufacturer.
Message 7 of 10
Guru
Try disabling AX Mode on the RBR and set CTS values to 2347.
AX mode are check boxes on the Basic/Wireless settings page on the RBR.
CTS is under Advanced Tab/Advanced Settings/Wireless Settings
Message 8 of 10
Chief2019
Tutor
Message 9 of 10
Guru
Glad you got them working. Please mark your thread as solved so others will know.
Enjoy. Smiley Wink
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 584 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
