Reply
Orbi rbk753s upload seed slowed down after installation .
bmanny93
Follower
After installing my new orbi rbk753s , completed speed test and my upload speed took a dive. I have Spectrum and use their modem. Having trouble with gaming
Message 1 of 3
Guru
Re: Orbi rbk753s upload seed slowed down after installation .
How are you speed testing? Wired speed testing is preferred.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, Traffic Meter.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 3
SubjunctiveCase
Having similar issue except I'm experiening severely slowers down speeds (~20 up) on hardwired PC. Running RBK753S from Verizon FIOS ONT. Getting over 900/800 at router. No double NAT issues. Traffic Meter and Armor = off. PC running directly to base router. Any idea wth is going on?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 183 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
