Reply
PC Doesn't Detect ORBI RBR750 Wifi
Roger10
Follower
My PC sees every WiFi signal available except the ORBI RBR750.  All my other devices see the ORBI signal and connect easily.  It should be pretty simple.  Any ideas?
Message 1 of 3
minesweeper
Re: PC Doesn't Detect ORBI RBR750 Wifi
PC driver may need an update. You can also try disabling 11ax in Orbi and see if it helps.
Message 2 of 3
Guru
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Be sure your wifi adapter drivers are updated for the mfr of the wifi adapter.
Good Luck.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 352 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
