Reply
Possible to add AX1800 satellite to AX6000 system?
Markedly
Tutor
Hi,
I already have an existing AX6000 router and satellite on our two floors.  We've recently extended into the loft, so need to extend wifi up to the new third floor.  The existing RBS850 satellite doesn't seem to offer much coverage up there, though I have established that the wireless backhaul would be fine.
To keep cost down, is it possible to add an AX1800 (RBS350) satellite to this setup?
Thanks
Mark
Message 1 of 6
Accepted Solutions
Markedly
Tutor
Re: Possible to add AX1800 satellite to AX6000 system?
Thanks.  I double checked with Netgear support and they confirmed:
"The only compatible satellites with your RBR850 are RBS850 and RBS750 only."
Message 5 of 6
All Replies
Guru
I don't think they are compatible. The 3 series is a dual band system vs the 8 series which is tri band system.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 6
Markedly
Tutor
In that case, how about adding an AX4200 satellite? I believe that line is tri-band
Message 3 of 6
Guru
Yes, the 7 series RBS will work...
Testing
Message 4 of 6
Markedly
Tutor
Message 5 of 6
Guru
Good Luck.
Testing
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 403 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
