Orbi WiFi 7 RBE973
Reply
RBK 353 - Constant Disconnections - Firmware 4.4.0.10
mgfeal
Hi,
I own a Netgear Orbi RBK353. Both satellites connected using Ethernet.
First weeks all worked with a few problems, but since I updated to firmware 4.4.0.10 (4.4.0.10_2.10.63 for the principal router) is unusable.
Devices disconnected every day. Devices that are one meter away. To solve it I need to reboot Orbi satellites.
Anyone with the same problems?
Thanks!
Message 1 of 12
Guru
Re: RBK 353 - Constant Disconnections - Firmware 4.4.0.10
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
@mgfeal wrote:
Hi,
Thanks!
Message 2 of 12
Obtc101
Hello @mgfeal did you find a solution to this and did the reset work?
I've been suffering the same issue since the firmware landed, having previously had a solid connection throughout.
When I review the router's logs on the web interface, it seems that my connection drop outs coincide with potential DoS attacks and scans.  I am aware of other users reporting lots of false positives for the DoS attacks, so they may not be genuine.  However in any case, the drop outs seems to correlate with them at the same time.
My ISP modem and connection during this period is fine, so it's definitely the Orbi network
Any advice appreciated
Thanks
Message 3 of 12
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Thanks
Message 4 of 12
mgfeal
I'm browsing to one of the satelites using its IP. And I discovered that 2.4GHz is not working. So devices are disconnected.
But I don't why. Orbi router has enable 2.4 and 5G.
Any idea?
Thanks!
Message 5 of 12
Guru
Then check boxes next to 2.4 and 5G are for enabled AX mode on the RBR. Not enabled of the 2.4G or 5G radios in general.
Has a factory reset of the RBR and RBS and setup from scratch been performed then check the RBS status page for 2.4Ghz?
Any idea?
Thanks!
Message 6 of 12
mgfeal
The RBR is the second snapshot. It has both signals enabled.
Now I reset the Satelite. It finished the sync and now it's working (image attached).
Message 7 of 12
mgfeal
Message 8 of 12
mgfeal
Sorry, I don't know why I can't upload images.
I'll monitoring the satellite the next days.
Message 9 of 12
Guru
Inline pictures have to be approved by a forum moderator.
Please use the Choose File button on a post to include the picture file for faster review.
Glad it's working better. Come back and let us know if there are any changes after a few days.
Message 10 of 12
mgfeal
After a few days working ok, the satellite is failing again. Image attached.
How I can get logs from this satellite?
Thanks!
Message 11 of 12
Guru
Satellites IP address/debug.htm
I recommend you contact NG support about this ASAP.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1443 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
