Orbi WiFi 7 RBE973
Reply
RBK734S versus RBK852 versus orbi pro SXR80 ?
stevelk9999
Tutor
I an interesting in upgrading my current Orbi System and was wondering which of the models above might be the  best?
Key needs
1. about 35 devices - minimal streaming - no games,  only 2 adult users
2. about 7 IP cams and Blue Iris - almost always local
3. I would like to isolate the IPCAMS from the rest of the network .  A secondary VLAN for IOT is good but not critical
4 Open VPN - Orbi was easy and reliable
Thanks for highlighting any differences. It is hard to tell side by side.
Message 1 of 2
Guru
Re: RBK734S versus RBK852 versus orbi pro SXR80 ?
Device isolation isn't a supported featured on Orbi home systems. Maybe possible at the pro level:
Something to ask about in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
You can review the spec sheets for the 7 and 8 series Orbi AX to see differences. There mostly the same accept for faster connection rates on the 8 series.
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 519 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
