- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK750 Series - Firmware Update v4.6.3.7
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK750 Series - Firmware Update v4.6.3.7
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good business model we'll make your system unstable so you buy our additional service but still get no resolution, so now you're even more PO'd
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Timothy88 wrote:
Has anyone looked at or have any experience with the ASUS ZenWiFi AX (XT8)?
You can find out all you need to know over at Small Net Builder forums.
- Mark as New
- Bookmark
- Subscribe
- Permalink
By the looks of it, they seem to have there own issues too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can the Orbi run DD-WRT or Tomato?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
nvram set auto_upgrade_enable=0
nvram set ver_check_https_svr1=http.fw.updates1.aaa.com
nvram set ver_check_ftp_svr1=updates1.aaa.com
nvram set ver_check_ftp_svr2=updates1.aaa.com
nvram set ver_check_ftp_svr3=updates1.aaa.com
nvram set lang_check_ftp_svr=updates1.aaa.com
nvram set install_fw_upgrade_latest=0
nvram set ver_check_enable=0
nvram set ver_check_ftp_password=aaa@aaa
nvram set control_cloud_backend_fw_url=https://http.fw.updates1.aaa.com
nvram set promotion_server=updates1.aaa.com
nvram commit
6. Make sure the above run on both devices.
7. Go to Managment page -> Advanced -> Security -> Block Sites :
a. Keyword Block set to "Always"
b. Add the following key words:
http.fw.updates1.netgear.com
c. Click Apply.
8. Perform a Soft reboot from Advanced Home : -> Reboot -> Connect back to the Internet.
9. After that, my firmware update page showing this:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, those are commands sent down AFTER the Orbi AX is downgraded to v3(v22) FW from v4. That stops the Orbi from auto updating from what the initial user posted.
@Theobuck wrote:
5. Telnet connect to both devices, and ran the following:
nvram commit
c. Click Apply.
- Mark as New
- Bookmark
- Subscribe
- Permalink
ALL USERS of the 7 series Orbi AX system, please contact NG support by opening a support ticket and contact NG and ask them for the beta that seems to be avialable for the 7 series that seems to be directed to fixed what everyone with a 7 series has been having problems with:
https://www.netgear.com/support/#
For user out of warranty, contact @Blanca_O and @DarrenM and send them a PM and ask for the beta.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The version looks the same.
https://kb.netgear.com/000063818/RBR750-RBS750-Firmware-Version-4-6-3-7
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://www.downloads.netgear.com/files/GDC/RBK752/RBS750-V4.6.3.7_2.0.49.zip
Replace the file version with the new version!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It didn't work, sorry.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd be interested in the Beta as it jsut crashed again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update: It has been more than 2 weeks. My Router and satellite stayed on V3 Firmware and running smoothly. For anyone who wants to try the workaround, you can refer to my previous post.
NG support called me last week to ask how my self-troubleshooting was going, I told them they should be ASHAMED of putting “Provide World’s leading stable Wireless solution” slogan on the product packaging box.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Back in July I upgraded my firmware to v4.6.3.7 and immediately lost the ability for my printer to connect via Wi-Fi. Multiple contacts with support got nowhere with a solution. I then had to leave town for a couple of months for business at which time my crappy 90 day support ended. By the time I got back 80 percent of my devices could no longer connect to Wi-Fi. Factory reset the router and started over. Things would work for a short time then again lose the ability to connect. I contacted support again and got them to make an exception and talk to me. They decided to send me a replacement unit but again with the same version of Firmware the same problem exists. Of course now I have no support and have a 5 month old brick on my hands. Not at all happy with Netgear for having horrible support policies and releasing very buggy firmware with no fix.
