- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK752- AX4200 Internet Dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi There,
I purchased this device 2days ago and have had constant issues since purchase. I phoned NG support yesterday and spoke to an 'orbi specialist' whom changed a few things will list below my current set up as per NG Support advisal.
The support advisor also explained that it maybe a hardware issue if the internet continues to drop - which seems like a cop out as opposed to NG actually knowing what the constant issue with there hardware is.
I previously had ORBI Rbr20 and it worked perfectly fine, the upgrade is due to the lack of coverage rbr20 offerred and not being able to purchase the satellites in NZ anymore.
To install the RBK752 i had to factory reset the hardware itself along with the satellite.
Since establishing connection it fails to stay connected for longer than 24hrs.
Current orbi settings are as follows:
2.4ghz -6
5ghz - 44
DNS Server - Google - 8.8.8.8/8.8.4.4
And I have just updated the CTS to 2347
I have a Huawei Modem.
model: HG630b
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBK752- AX4200 Internet Dropping
Do the front LED turn on PINK when this happens?
Does wireless and wired connections fail?
What mode is your modem working in? Router or Bridge mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK752 (Router Mode), Wired Backhaul and R8500 with Orbi RBKE963 (AP Mode), | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
