Orbi WiFi 7 RBE973
Reply
RBK752 - Awesome but disconnects on facetime a lot
mnichollsuk917
Hey all
Firstly, i love my RBK752! The router & Satellite have transformed the WIFI in my house but there is one odd issue
My iPhone doesn’t like it, it seems to be ok when my iPhone (11 pro max) is on the main router but when its on the satellite it disconnects, but i never have an issue with the apple TV or the Alexa on the same satellite.
My phone drops out to 4G, then pops back onto WIFI and it just keeps happening
The Netgear page says the backhaul is good, but every now again a blue solid lights appears on the satellite, this maybe happens once every few days for a couple of minutes
Any ideas please? thank you
Message 1 of 113
Guru
Re: RBK752 - Awesome but disconnects on facetime a lot
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling  WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Message 2 of 113
mnichollsuk917
Hey,
Thank you for the reply.
My home is 1500 square feet, the satellite is around 30feet away from the router going through 4 plasterboard walls. The link status says "GOOD" but every few days the light on the satellite goes solid blue and i have to reboot to make it turn off
2.4 is using AUTO
5 is using 36
I will now change to 2.4 - 1 and 5- 48 and provide feedback.
There are lots of other wifi routers in the vicinity
WMM is already enabled
I have disabled 20/40Mhz Coexistence
i can see the CTS threshold but cant seem to amend it?
when i changed 5ghz to 40 i get a message saying my service rate will drop to 20ghz which corresponds to a 286.6 mbps performance?
Set Short preamble instead of Long preamble modes -  where is this setting ?
thanks for your help i appreciate it
Message 3 of 113
mnichollsuk917
udpated on above, i have now changed both 5 and 2.4 to short & CTS on both to 2347
Message 4 of 113
Guru
Let us know how it goes...
Message 5 of 113
mnichollsuk917
My iphone is disconnecting more thasn ever at the monment, any ideas please?
Message 6 of 113
Guru
What happens when you disable AX mode on 2.4Ghz?
Message 7 of 113
mnichollsuk917
Is the below ok - it’s the message I get
Per Wi-Fi Alliance guidelines for 40 Mhz and 20 Mhz coexistence, even if you select "Up to 573.5Mbps" mode, your product's service rate might drop to 20 Mhz. This typically corresponds to286.8 Mbps performance
Message 8 of 113
Guru
Yes.
You can set 40Mhz only as well under Advanced Tab/Advanced Settings/Wireless Settings. Just uncheck the check box next to 20/40Mhz.
Message 9 of 113
mnichollsuk917
Can does the 40mhz setting offer please? Thanks
Message 10 of 113
Guru
Yes.
Message 11 of 113
Mikey94025
Hero
The OP's iPhone 11 Pro Max should be connecting by 5Ghz, so the 2.4Ghz settings shouldn't matter.  Isn't this a more likely problem to investigate?
Message 12 of 113
mnichollsuk917
I did wonder if it was the AX on 5GHZ that I should turn off rather than the 2.4?
Message 13 of 113
mnichollsuk917
Just reading about AX, is this fundamental for WiFi 6? What functionality is lost with this setting disabled? Thank you
Message 14 of 113
Guru
Yes test both frequencies with disabling AX mode and see if this resolves the disconnects.
Others have reported this as well.
Message 15 of 113
mnichollsuk917
It seems to disconnect less but I have just been on a FaceTime call and it disconnected even though AX is disabled on both frequencies- next idea please 😊
Message 16 of 113
mnichollsuk917
Hi have had 3 WiFi disconnections on FaceTime / iPhone this morning. I have been working from home and work laptop is fine, really does seem an iPhone related problem - any other ideas please?
Message 17 of 113
mnichollsuk917
Ok, to confirm, when i reset this will keep the newest firmware onboard?  i presume once it is reset i should amend any of the setting such as AX etc? just try it with default settings initially?  Thank you
Message 19 of 113
Guru
Yes and Try default settings, if not try disabling AX mode and set CTS to 500 or 2347
Message 20 of 113
mnichollsuk917
I will hopefully have time over the next week to try resetting it all. Out of interest this issue only happens with my iPhone, never my iPad - why would this be? Merry Christmas all 😊😊
Message 21 of 113
Guru
iphones seen to be more promatic than pads.
iOs versons could be a factor.
Merry Christmas.
Message 22 of 113
mnichollsuk917
Hey
Thanks for your comments
The issue was happening on the old firmware and it’s just as bad on the newest firmware - could it still be a firmware issue?
Message 23 of 113
mnichollsuk917
I just don’t understand how a £400 bit of kit can work with almost everything, we constantly have 3 Apple TV’s streaming 4k at the same time without a problem but every single FaceTime call I have drops onto 4G, it’s infuriating. My partner is not going to be happy if I change the hardware as it works great for her; she doesn’t see an issue. I just don’t understand how this can be an issue that isn’t quickly resolved! It seems to be quite widespread as well
Message 24 of 113
CrimpOn
Guru
Is there an option on the iPhone to disable LTE data?
Do you know anyone who could bring a different device over to test Facebook with?  (Perhaps an iPad with no cellular radio)
Message 25 of 113
Top Contributors
Discussion stats
  • 112 replies
  • 2794 views
  • 8 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
