Orbi WiFi 7 RBE973
Reply
RBK753 DNS Setting greyed out
wxd4000
Hi, I have a Orbi RBK753 mesh wifi system, I recently noticed the DNS setting is greyed out, and I am no longer able to use my NAS as my DNS server. I have tried to reboot the router and disable the parent control, but neither helps. The firmware version is V4.6.5.14_2.0.54. Is there anything I can do?
Message 1 of 5
Guru
Re: RBK753 DNS Setting greyed out
Be sure Armor or Smart Parental Controls are not enabled.
Netgear has set up a community forum specifically for the Orbi AX products. Most of the people who watch that forum are more likely to have experience with Orbi AX (WiFi6 RBK 3,7,8 and 9 Series) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 5
Guru
Are you running it in access point mode?
Got a screensnip?
Are you using armor?
Message 3 of 5
wxd4000
Thank you for your reply!
It is not in AP mode. Armor and parental control are disabled. Screen shot is attached. You can see the DNS setup is grey-out, the router MAC address is also not able to be changedorbi router.png
Message 4 of 5
Guru
have you tried a factory reset?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1247 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
