Orbi WiFi 7 RBE973
Reply
RBK850 Routeur LAN configuration
thierry38
Star
Hi
I configured an RBK850 (without satellites for the present time) connected to ans ISP router (network 192.168.1.<x> with HDCP server). So, at the end of installation, my orbi network is 10.0.0.<x>. Wifi and LAN connections are working well and only one PC is connected to ORBI router with an Ethernet cable.
I want to change the ORBI network to 192.168.2.<x>. So, I made the following modification
- IP @ : 192.168.2.2
- Mask : 255.255.255.0
- DHCP from 192.168.2.10 to 192.168.2.254
When I apply the modification, the router is restarted, the LED is white blinking during 1 mn and it restarts again and again. I've to reset it with default settings to stop the restart cycle.
How to do such modification ? (it works perfectly on an old netgear router).
Thanks
  Thierry
PS : firmware version : V3.2.18.1
Message 1 of 6
Guru
Re: RBK850 Routeur LAN configuration
Did you power OFF the ISP router for 30 seconds then back on as well after you applied the change?
Can you bridge the host router by chance? This is a double NAT condtion...
Message 2 of 6
thierry38
Star
Yes, I powered off the ISP router and I can access to internet. I just received an answer for neatgear support
It seems the router DOES NOT support to have a 192.168.2.2 IP @. If I choose 192.168.2.1, it seems it’s working well.
I will continue tomorrow (11 PM in France now) And I will give you more information later. I lost several hours with the pb
Thanks
Message 3 of 6
Guru
I now mine works on 192.168.0.1. I've never tried 2.1 though...Hmmm.
Have a good night.
Message 4 of 6
thierry38
Star
Hi,
Just for information, with a router IP @ of 192.168.2.1 instead of 192.168.2.2, everything are working well.
After this modification, I successfully
- desactivate the router DHCP fonction (used instead a DHCP located on my network)
- add two additional satellites
So, it seems there is a bug in the orbi firmware which doesn’t support 192.168.2.2 as router address
Best regards
Message 5 of 6
Guru
AH ya, Ok. I  presume the RBRs IP address should always be .0 or .1. Maybe something NG put in. Most routers IP address usually end  in .1  anyways.
Glad it's working now. Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Please mark your thread as solved so others will know.
Enjoy.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1131 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
