- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK850 Series - Firmware Update v4.6.3.9 - Issue with wired satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I see that there is a new firmare for RBK850 to enable parental control. The firmware is v4.6.3.9.
I downloaded this firmware and installed it.
The only "nasty" issue I see with this firmware is that wired satellites don't work. 🙂 The wireless satellites work well.
Otherwise all is so far so good.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset of the Router solved the problem with wired satellites. 🙂
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK850 Series - Firmware Update v4.6.3.9 - Issue with wired satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's important to know that downgrading back to v3.2.x.x is not possible in the Orbi Router. The Satellites are ok to downgrade.
So once you upgrade to v4.6.3.9, it seems that you will be stuck on that firmware.
Also note that Orbi Router v4.6.3.9 will work with Satellites on v3.2.x.x. All Satellites will appear as disconnected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Glad that was all.
