- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK850 to current setup
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all, had a RBK850 system setup in wireless mesh. Getting weak signal in some parts of the house and was able to get my hands on another RBK850. I added the satelite to the current RBK850 setup and now want to see what I can do with the RBR850.
Is there a way I can add teh RBR850 to the current mesh setup? I can connect it to the main RBR850 using ethernet if that helps.
Also is there a way to run some of the RBS850 wired back to the original RBR850 (where i can) and the other wireless as some of the satelite have ethernet connects available to them?
Thanks in advance.
C
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK850 to current setup
What is the distance between the router and satellite(s)📡? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite📡
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
You can use the 2nd RBR850 in AP mode. I won't be included in the 1st MESH system though.
- Mark as New
- Bookmark
- Subscribe
- Permalink
V3.2.18.1_1.4.14
Running NBN in Australia so going directly and connecting via PPPoE
480 Sq Ft across two floors
Both are within 30ft, however the house is all double brick wall internally
6 in 2.4Ghz and 48 on 5Ghz
Depends on where in the house, but no more than two other WiFi
You can use the 2nd RBR850 in AP mode. I won't be included in the 1st MESH system though. Why’s that? Looking to keep everything on the same network so there’s seamless transfer.
Another issue I am having is the wifi keeps dropping out and the handover from one satellite to the other seems to drop connections for ~5 seconds. Both are expedited if I am on Zoom callls.
Thanks again for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both are within 30ft, however the house is all double brick wall internally" Possible that brick will impact the signal coverage and cause wifi conenction problems. So if you an get the 2nd RBR setup in AP mode ethernet connected to the 1st RBR, this may help you.
The 2nd RBR doesn't support working like a RBS. It will only work as the main router and wifi or in AP mode having its own SSID name which can be connected to the 1st RBR via ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would the double brick also explain the connection drop when change from one satellite to the other?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Probably yes. Singal for the connecting device is probably low or noisy and the device and connection takes a bit longer than expected...
