- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK852 Wifi Calling not working and Wifi connectivity problems
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi 852 for about a year now. I have been using wifi calling flawlessly up until today. My phone is set up to switch over to wifi calling when the cell signal drops out while on a call however today it says it cannot switch over to wifi calling. I've been through a few checks now and it seems like the issue is my router. It updated to the new firmware V4.6.3.16_2.0.51 and based on the other posts about this update I'm guessing it has to do with that. I've reset the routers and my device. I've seen in some other threads that disabling SIP ALG will fix it but it hasn't. In fact now my phone can't even use the wifi any more. Just says there's no internet access.
Any ideas on how to fix?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK852 Wifi Calling not working and Wifi connectivity problems
Is Armor enabled on the RBR?
Does same thing happen if you turn OFF the RBS? Just connect to the RBR?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same issue on both mine and my wife's phones start a couple of days ago. I spent 10 hours on the phone with Apple, Verizon, Comcast, and Netgear troubleshooting and resetting everything yesterday, to no avail.
Today, I may have stumbled on the fix. I can't believe it's as simple as it is.
In the control panel on the iPhone,
The phone has to be in airplane mode, and the cellular antenna button has to be off. This forces the phone to use the wifi signal, and not look for the Verizon signal at all. Picture attached. Hope this fixes your issue as well.
RBR850 mesh router
Arris 8200 modem
iPhone 12 mini
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seesm like the iOS is not picking the better signal or is flopping between cell and wifi only. Would be a iOS issue possibly.
RBR850 mesh router
Arris 8200 modem
iPhone 12 mini
