Reply
RBK853 BackHaul
BobbyOnyx
RBK853 BackHaul
Hi Guys,
I've searched the forums and cannot find the answer but apologies if it out there and has been asked before.
I am 99% sold on purchasing the RBK853 WiFi 6 mesh system but have a question regarding back haul which I believe is not the usual question people have!
My setup will require the use of one of the satellite's as a switch, utilising 2 of the rj45 ports for my pc and NAS and then hard wired back to the router.
My question is, is it possible to forcibly tell the hardware not to use this Ethernet connection back to the router as a back haul?
In simple terms, can I force the orbi to use wireless back haul rather than my Ethernet connection?
I hope this makes sense.
I look forward to your replies
Message 1 of 4
Accepted Solutions
Guru
Re: RBK853 BackHaul
Anything is possible, however if the RBR and RBS have GOOD status and get full on 2400Mpbs backhaul connection rates, then this could have better performances vs 1000Mbps on the wire though wire mostly has the best stability and performance vs wireless. Something you can test and see what works best for your environment.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 4 of 4
All Replies
Guru
Re: RBK853 BackHaul
IF the RBS are ethernet connected to the RBR, then the RBS will always use Ethernet backhaul for data flow to the RBR.
Testing
Message 2 of 4
BobbyOnyx
Re: RBK853 BackHaul
Thank you for your answer. Not ideal for what I had planned but at least I know for sure so I can make an adjustment to my setup.
I understand it's a "how long is a piece of string" question but will I see much performance loss from my PC/Nas if I did use the Ethernet cable as described above and it was also used as back haul?
Message 3 of 4
Guru
Re: RBK853 BackHaul
Testing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 408 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
