- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK853 - Satellites drop Internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
we have a RBK853 package and since initial installation we have the problem that the Internet connection is dropped multiple times during the day from all 2 satellites. Totally annoying when you have to work from home with stable WiFi. We have tried almost any possible channel settings and the Orbi is running in AP mode only.
If anybody has any suggestion how to solve this, that would be much appreciated!
In touch with NG support since 4 weeks to no avail so far.
Many thanks,
Mike
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a full power OFF of the RBR and RBS been perfomed since last FW update?
Try disabling AX mode on the RBR for 2.4Ghz...
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853 - Satellites drop Internet connection
Hi there,
thank you for your quick reply.
Firmware is V4.6.3.16_2.0.51
The modem is a Telstra Smart modem, we previously had an Orbi RBR50 plus 2 Satellites RBS50 working fine on the same setup.
Home is a 2 story 300 sm single dwelling.
When connected both Satellites show blue colour indicating they successfully synced and the connection between the router and satellite is good.
Currently using channel 5 (2.4 GH) and 36 (5 GH).
2 Wifi neighbours at least 15 m away.
Yes full power off and hard reset has been performed multiple times.
ok will now try disabling AX mode for 2.4 GH.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there a model # for the Telstra Smart modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry dont have a model number for the Telstra Smart Modem.
Seems like disabling AX mode for 2.4 GH has been a positive impact so far and drop outs have reduced considerably.
Our Internet comes into the house in kind of the middle of the ground floor. We tried putting one Satellite in the far corner room of the house (more than 10 m away) but it always showed poor backhaul status in the Orbi Web interface even though the LED light was blue upon connection to the RBR850. Now it's maybe 5 m away but two walls inbetween, backhaul status is now showing as good. The other Satellite is upstairs more than 10m away also showing backhaul status as good. Once we have solved the drop outs I will try and put the Satellite downstairs back into the far room.
- Mark as New
- Bookmark
- Subscribe
- Permalink
