- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK853 Solid White Light After Power Cut
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware Version V3.2.16.22_1.4.9
We had a couple of power cuts last weekend and since then the LED on the modem has stayed on solid white. I have tried power cycling etc. but the light remains on. Everything is working fine but the light remains. Should I leave it as everything is working ok? Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853 Solid White Light After Power Cut
ON the modem? The RBK is a router and satellite system. No modem.
Did you try powering off both router and ISP modem for 30 seconds then back on with the modem first, then router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, sorry on the router. I have tried switching both ISP ONT & router off for 30secs then switching on the ISP ONT on then router once that booted up and showing green status. White light remains on solid on router. Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the ONT and RBR. Cat 6 is recommended.
You might try a factory reset on the RBR and setup from scratch..
