- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBK853 measure beackhaul signal strength to position satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m wanting to place one of my satellites permanently on a wall. I’d like to measure the signal strength for the wifi backhaul to do so optimally.
However, the SSID for those is hidden and I can’t find anyway to either figure out what they are or temporarily make them visible so I can use a signal strength testing tool.
Is there anyway to do this?
The best I could come up with is to use the public 5Ghz and 2.4Ghz SSIDs as a proxy. Doing so I’ve determined there’s about a 10 point difference in RSSI and SNI depending on where I place the laptop I’m using to test.
Is that going to be a sufficient proxy? Is there a better way to work out where to position satellites?
Thanks,
Simon
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBK853 measure beackhaul signal strength to position satellites
The wifi back haul is hidden and not user configurable.
They may show in some wifi scanning apps with out any SSID name on the higher 5Ghz channels 149 thru 161.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
