expertgas's avatar
expertgas
RBKE963
Hi all,
This night Orbi system has upgrade automatically the firmware (from V6.0.3.85 to -V6.3.7.5) and since this morning router (RBRE-960) doesn't see satellites (2X RBSE-960) no more.
No solutions to reconnect both satellites with new firmware.
Downgrade satellite 1 to old firmware (V6.0.3.85) and now i had reconnect successfully.
I'm a PC technician and I think that new firmware (V6.3.7.5) has BIG BIG BIG problems.
Please feedback analog situations. Thanks.
Simon
  • plemans's avatar
    Whenever there's issues after a firmware upgrade, one of the first troubleshooting steps we recommend is a factory reset and then reinstall. Did you try this?
    • expertgas's avatar
      expertgas
      This afternoon i have downgrade to previous version and manually re-upgrade to last version, but wifi performance was very bad (not over 200 Mbps on 2.300 Mbps FTTH). So I have downgrade again to previous version and now it's all ok.
      • RafS's avatar
        RafS
        Apprentice
        I had issues when i first upgraded to 6.3.7.5 as well, all devices were showing as N.A. in the app and speeds were slow as well.  What solved it for me was to do a reset via 192.168.1.1 login, then load the firmware again on each satellite, then the router, power everything off, and set everything up from scratch. It’s a pain to do and took about 90 minutes since I have some devices that have assigned IP addresses but everything has been up for about 2 weeks now without one issue.  I was on a beta firmware before this and it was not a good experience so this is definitely a very pleasant change for everything to work like it did when I originally bought these.
  • FURRYe38's avatar
    Be sure that the RBS are updated BEFORE the RBR is.
    Mines on current v6.3.7.5v code and ran well for over 10+ days fine.
    expertgas wrote:
    Hi all,
    Simon
      expertgas
      It's exactly what i've done. Satellites first. And, update of this morning. Even if i've disable automatic udates, this night Router and satellites has been upgrade automatically and the same problem of saturday morning is back !!! Now i'm updating manually... But this scenario is abolutely not good.
      Moreover, with new firmware, wifi performance is very bad ad unstable.
        expertgas
        Now in our store we have a problem with electronic price label. Since last update the prices don't update no more. Yesterday I've made an hard reset, but problem still remain. And i don't understand why after speding 1.700 euros, I must pay for a netgear technic assistance, where the problem is the new firmware. And in I downgrade and try to disable automatic updates, firmware upgrade itself anyway. For us it's A BIG PROBLEM.
  • iyang's avatar
    iyang
    NETGEAR Expert
    Hi expertgas ,
    Can we know how satellite(RBS960) connect to router(RBR960) ? wireless 2g or 5g or wired ?
    Thanks.
      expertgas
      Both wired (Cat. 6). All Netgear switches (1Gb and 10 Gb) are UNmanaged.
      • FURRYe38's avatar
        Is the CAT6 UTP or STP? STP is recommended if your using the 2.5Gb LAN Ports between the RBR and RBS.
        What is the brand and model# of these un-managed switches?
