- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBKE963B - Help with optimal location based on house plan
- Mark as New
- Bookmark
- Subscribe
- Permalink
We're building a new construction home and are currently in the planning phase. We do have our house plan finalized and would greatly appreciate any insights as to the optimal placement for the router and two satellites. If anyone is willing to take a look, please reply here and I will message you the house plan.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBKE963B - Help with optimal location based on house plan
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, yes, if you can get CAT6A cable in wall infrastructure in place during the build out, then you'll be good. I did this several years ago when we did a new addition to my home. CAT6A in wall and patch panel in a central electronics location. Main level is recommended, not in a basement. Mines on 2nd level. Then run CAT6 patch cables from wall outlets to devices, RBS and such.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Telcom wiring in residential structures has evolved over the years. At one time,builders would put a patch panel in the garage and then home owners would find that this location was horrible in terms of air temperature and electrical needs. Since this building is totally new, I would want to consider (a) how is the Internet Service Provider going to get service to the house? (because either the modem/fiber box and router have to be located there, or (b) there needs to be an ethernet cable from that location to where the router will be, and (b) where in the house will it be convenient to locate a patch panel and a bunch of electronics that all need to be [relatively] cool and have electricity?
I would definitely install a bunch of cables to the basement (leave them rolled up near the ceiling.
Also, if you plan to install security cameras, now is a good time to install ethernet cables to the most likely locations.
