Orbi WiFi 7 RBE973
Reply
RBR 850 see no firware update
Wilocat
Tutor
After i login to orbi login and i go to firmware update i got the message "No New Firmware Available' (Pressent Firmwareversie
V3.2.18.1_1.4.14)  but at the moment is the actual newest firmware 4.6.3.9
Why can orbi not find the new firware. And how can i make i possible that it works.
Status:
  Model Name Apparaatnaam Huidige firmwareversie Status
RouterRBR850RBR850V3.2.18.1No New Firmware Available
SatelliteRBS850Orbi Satellite-1V3.2.18.1No New Firmware Available
Message 1 of 7
Guru
Re: RBR 850 see no firware update
Some systems are not made available for auto updates. One can manually update FW:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
It's recommended if your system IS working, hold of on upgrading.
Message 2 of 7
Wilocat
Tutor
Thanks for the answer, its upgraded
Message 3 of 7
Guru
Let us know how it works for you.
Message 4 of 7
Wilocat
Tutor
At the moment i got no problems, but now i see by udpdate a  new firware for the router and a downgrade for the sattelite ????
RouterRBR850RBR850V4.6.3.9V4.6.3.16
SatelliteRBS850Orbi Satellite-1V4.6.3.9V3.2.18.1
Message 5 of 7
Guru
Intersting. Not sure about that...I'd leave the system for now.
Message 6 of 7
FarmerBob1
Luminary
Any Flames?!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1091 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
