Reply
RBR 853 firmware 3.2.17.12_1.4.14 has issues
Flupke
I recentely upgraded to the firmware 3.2.17.12_1.4.14 from v3.2.16.22_1.4.9
Although at first glance everything appeared OK, it appears there is a serious disfunctioning has the "port forwarding" parameters are not reliably supported anymrore. I had no problem with the former firware.
My Internet connection is established using PPOE.
When rebooting the router everything is working fine: incoming traffic can successfully be routed.
However, after a while it is not the case anymore. Smiley Sad
If I reestablish the PPOE connection it works again but only for a short while.
I didn't change anything but for the firmware upgrade.
I contacted the support of my Internet Service Provider and they said they didn't change anything (of course I am not in position to verify this statement)
I am considering to roll-bak to v3.2.16.22_1.4.9
Message 1 of 5
Accepted Solutions
Flupke
Re: RBR 853 firmware 3.2.17.12_1.4.14 has issues
Since I disabled uPnP, no more issue.
Message 4 of 5
All Replies
vajim
Master
you may want to post your question/cncerns here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Message 2 of 5
Flupke
The issue seems related to the UpNP feature of the router.
When I esablish the PPOE connection (reboot of router and/or ADSL brtidge) it worked fine for a while.
I searched in the Orbi logs and noticed that briefly before it stops functioning ...there is the trace:
[UPnP set event: AddPortMapping] from source 192.168.x.x, Monday, Mar 08,2021 11:04:08
This seems to come from a Foscam camera.
Strangely, if I look at the UPnP Protmap table on the Orbi, there is no trace of anything.
I suspect that the UPnP port mapping request of the Foscam camera is leading to a "corruption" of port mappings on the basis of which the router becomes deficient in handling my manua "port forward" rules as well.
This is imho a serious security issue as a single device can lead to a disfunctioning of the router.
If confirmed It is either a problem related to the firmware (as I didn't notice issues before), either a corrupte PortMap table after the firmware upgrade process (which could be resolved by doing a factory reset but I am not eager to do this as it can lead to problems).
From now on,
- I disabled UPnP on the Foscam camera (which wasn't an easy task as the process to go to their admin console is cumbersome)
- I disabled UPnP on the router as well
If the issue is disappearing I may consider reactivating the latter
Message 3 of 5
Flupke
Message 4 of 5
Guru
Be sure to make a backup configuratyion to file for safe keeping. Helps save time if a reset is needed.
Enjoy. Smiley Wink
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 497 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
