× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
RBR20 won’t allow connection to Earthlink SMTP server
Rcot
I have an RBR20 with two satellites. EVERYTHING works fine withe exception that I can’t send email through Earthlink’s SMTPAUTH.EARTHLINK.NET server. I’ve tested this using two different accounts on 2 iphones, 2 ipads, and 2 Win10 laptops. The iOS devices were tested using the native mail app and Outlook, and the Win10 machines used Outlook. If I turn off WiFi and use LTE, the Apple devices send OK. I swapped the Orbi router for a Linksys router and all is well. After talks with both Apple and Earthlink, plus three days of testing, it seems clear that the problem is somewhere in the Orbi RBR20. Can anyone shed any light on a fix?
Message 1 of 2
Guru
Re: RBR20 won’t allow connection to Earthlink SMTP server
Please post about this over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 156 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
