- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR350 - satellites syncing multiple times per day - unstable backhaul?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I bought RBR350 with two satellites. The Router is at the top floor and the satellites are on the middle floor. Between each of them is approx 10m/30ft. The issue I have are the teleconferences, which can freeze up to 10 seconds, then all continues as usual. I also noticed, that the satellites blink (white light) multiple times per day.
My settings are:
2.4 20/40Mhz coexistence off
UPnp off
WMM off (set directly through debug page).
Everything else is set to default. Does anyone have any idea why the above problem is happening?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR350 - satellites syncing multiple times per day - unstable backhaul?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
@dvladar wrote:
Hi,
My settings are:
UPnp off <Should be enabled
WMM off (set directly through debug page). <Should be enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What happens if you turn OFF one of the farther RBS and leave the other one running?
- Mark as New
- Bookmark
- Subscribe
- Permalink
