- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 drops internet on 5 GHz only requiring reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
My Orbi RBR50 (firmware V2.7.2.104) has been acting strange since the firmware update. I noticed that the WiFi connection is strong for both 2.4 and 5 GHz but internet only works for the 2.4 GHz connections. For example, my devices connected via 2.4 GHz connects to the internet but by devices that connect via 5 GHz (while still maintaining a strong WiFi signal) can't connect to the internet. The fix is to reboot the Orbi (not the Comcast modem) and both 2.4 and 5 GHz connected devices work...until a a day or two the 5 GHz devices stop working (requiring a another reboot). Both 2.4 and 5 GHz have the same SSID.
Has anyone come across this issue where the 5 GHz WiFi is strong but no internet while the 2.4 GHz is working fine?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBR50 drops internet on 5 GHz only requiring reboot
Also what is your NTP settings configured for? What time zone are you located in?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
