- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR50 slow wifi speed with FIOS
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have gigabit service from Verizon and 3 Orbi devices. The router is connected directly to the FIOS ONT, no Verizon router. Wifi speeds are <400Mbps, usually around 200. Wired connections are strong, close to theoretical maximums.
What Firmware version is currently loaded? V3.2.18.1_1.4.14
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Alcatel I-211M-L
What wieless device are you using? iPhone 12 Pro, Pixel 5
What are your wired speed results with a wired PC or laptop? 850+Mbps
What is the size of your home? Sq Ft? ~4500
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. Hardwired
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. Have tried both auto and setting various manual channels.
Any Wifi Neighbors near by? If so, how many? No interferring wifi from neighbors
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR50 slow wifi speed with FIOS
Confirming you have a RBR50 or somethig else?
"RBR50 slow wifi speed with FIOS"
What are your wired speed with a PC or laptop connected to thr RBR?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, RBR50 with two satellites. I have a switch downstream of the RBR, wired speed tests directly to RBR and behind the switch are the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try enabling WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is no option to set Coexistence to a certain value, only a checkbox to allow it or not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Removing the check from the box sets 40Mhz only.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried all the recommended actions including a factory reset yesterday. Wifi speeds are still avg around 200-250 Mbps. Any other recommendations?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Use WiFi Sweet Spots on your mobile devices to see what the connection rate is between the RBR and these devices. Turn OFF any RBS before testing. Test with the mobile devices about 6 feet from the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tested with Wifi Sweet Spots, 6 ft from router and satellites off, getting ~550Mbps there. Definitely not getting those speeds with other commonly use tests though...
