- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 403 Access denied after upgrade to 4.6.3.7 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I'm getting a proxy error from the router, and am unable to access its configuration page after firmware update from 3.x version to 4.6.3.7.
I factory reset the router, and then I'm able to connect again; however, when I re-configure it (restore settings), the proxy error comes back.
Access denied
The administrator of this proxy has not configured it to service requests from your host.
Generated by tinyproxy version 1.11.0-rc1.
I've tracked it down to the following:
I configure my router to be 192.169.0.1, rather than the default 192.168.1.1, and this configuration has worked well before (using 3.x firmware) and is necessary due to the topology of my various networks.
Anyhow, the new firmware is unable to handle this setting, even though the 3.x firmware worked fine.
Furthermore, the web application is not allowing me to downgrade to the older firmware because the "Yes" button that is required to answer the "are you sure you want to install older firmware" is missing from the UI.
Any hints on how to get around this error or an easy way to get past the "missing Yes button" part of manually downgrading.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: RBR750 403 Access denied after upgrade to 4.6.3.7 firmware
What browser are you using?
Bye restoring the configuration, are you manually inputting settings or restoring from a backup file?
If you disconnect the RBR from the ISP modem, can you log into the RBRs web page and select the ERASE function from Advanced tab/Admin/Backup using a wired PC and web browser? Try MS Edge or Firefox or Opera. After the RBR resets, log into the RBRs web page at 192.168.1.1 and walk thru the setup wizard...
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I tried Brave, Chrome, and Edge browsers, all with the same effect.
I've isolated the change to what I stated: i.e. I can make the error happen simply by taking the initial default configuration (after walk-through setup) and trying to change the router ip address to 192.169.x.x rather than 192.168.1.1.
The issue happens regardless of whether or not the router is connected to the cable modem.
Modem is Netgear CM1000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
You'll need to keep 192.168.1.1 for now if this doesn't cause a problem.
I recommend you contact NG support and let them know what your seeing when you try changing the IP address from .1.1 to something different.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Unfortunately, this is not a solution for me because I need this specific network numbering topology. Since this worked in previous firmware versions, how do I revert to an older version of firmware? When I try via the web UI, there is no "Yes" button to confirm the "version you're installing is older than the current version" question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No downgrading isn't supported. Contact NG support and let them know whats happening.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Yikes! What a mess.
Thanks for your help. I guess my best bet is to try to take the set back to Costco and hope that their generous return policy will allow me to get a replacement set that still has the old, working firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Ya you can try that.
Ya, NG knows of the v4 problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@adolgov wrote:Yikes! What a mess.
Why do you need to use a publically routable IP address range for your router?
Is this block of IP addresses actually assigned to you?
Perhaps it working before was a bug since you really should use private IP address range within your home.
Why can't you use the private IP address range 192.168.0.x in your home?
Although that could well be a problem too since, as you describe, using an alternate address range has become a problem.
Nevertheless the address range you were using isn't one you should be using.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I understand, this may not be the correct forum, but my initial point is that this issue is not limited to a single model or one exact firmware version.
Second point... THANK YOU, raven_au, for mentioning the Public/Private IP thing. I've been chasing my tail trying to figure out a fix for my 192.100.17.x IP range causing the same issue since my last firmware update. And since that range worked flawlessly in former firmware versions & on more than 8 other router brands & models for over 10 years, it didn't occur to me that my chosen IP range was the cause.
Fortunately, I didn't have to suffer through Netgear's absolutely HORRIFIC, sad excuse for technical support... I thank my luck stars again for that, alone!!
NETGEAR - Please, please document this new limitation within your firmware release notes!!
Had it been declared there, it would have been a huge favor to all of us... And we wouldn't have wasted so much time chasing it down. Whether the behavior was previously allowed via a "bug" or not is irrelevant. It's quite clearly a functional change implimented via firmware versions. Thus, should be documented as such.
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
In another thread it's been suggested that the "Yes" button can be found by examining the page HTML. Haven't tried it myself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Try this:
@GreatDrivr wrote:
Got an RBK852 & having the exact same issue on Firmware 4.6.3.9.
Thanks,
