- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 - Cannot port forward to PC connected to satellite router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Using latest firmware V4.6.5.14_2.0.54
Computer is running Windows 10
Setup: Spectrum Modem -> wired connection to Orbi base router -> wireless connection to Orbi satellite -> wired connection to PC
(The PC is wired with a CAT7 cable to the Orbi satellite, which is wirelessly synced with the base Orbi router)
The PC in question can connect to the internet just fine in this configuration, but when viewing the connected devices on the router administration page, the PC is not included. It is also not included on the devices for setting up port-forwarding. I've tried manually setting its static IP for port-forwarding, but the port still couldn't be reached when I tested it.
Is there a way to access this PC from the router admin page or otherwise port-forward to it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 - Cannot port forward to PC connected to satellite router
Please define "static IP" (it can have multiple meanings)
- The IP was defined on the PC as static, and is within the Orbi IP subnet.
- The IP was "reserved" for the PC on the Orbi LAN setup page using the PC MAC address.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
The IP was changed from DHCP to static on the PC. It doesn't show in the orbi device list in either configuration, however
- Mark as New
- Bookmark
- Subscribe
- Permalink
With my batting average now.... zero, some random thoughts:
Static IP. I avoid static IP's partly because I tend to make typos when entering the parameters and do not double check my work. Everything has to be exactly correct: (a) being in the correct IP subnet, (b) having the correct subnet mask, (c) setting the gateway IP address, and even the DNS settings. Anything not perfect causes problems.
Connectivity. With the PC able to use the internet, it should be reachable from other devices on the LAN. i.e. Can it be pinged from a different device?
Firewall. The most typical issue with forwarding ports is that many computers (such as Windows) have different firewall rules for Private (the local LAN) and Public (everywhere else) access. If the device ever appears to the Orbi and port(s) are forwarded to it, firewall rules become critical. People frequently comment, "it works fine from home, but xxx web site claims the ports are not open," when the firewall is blocking Public access.
Satellite vs. Router. Would it be possible to (temporarily) connect the PC to the Orbi router rather than the satellite? I keep a couple of 50' ethernet cables around for just this purpose. The family could not stand ethernet cables running through the house, but every once in a while I have the house to myself and can string a cable to a device. Since this situation is "not supposed to happen", it would be useful to be able to state that the PC behaves normally when connected to the router but abnormally when connected to the satellite.
850 Firmware Issues. There is an absolute frenzy going on over in the AX community forum over the version 4.x firmware (as compared to the 3.x versions), especially with regard to satellites. I see plenty of frustration and even signs of desperation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is your Spectrum modem also a router or not in bridge mode? If you have Double Nat then often that causes port forwarding confusion. This post has some steps for us to diagnose your port forwarding problems: https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/Community-FAQ-My-Orbi-port-forwardin...
You should be able to port forward to your PC's internal IP address. Let us know what you find when following the steps to determine if you have Double NAT and what https://canyouseeme.org/ outputs (step #1). Also check if your PC is Windows that you have set the Orbi connection to Private Network (step #3).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe something with prior PC then?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I wouldn't think so. I've port-forwarded from this computer before, using a different router. The computer that I can PF with is connected wirelessly, and the one I cannot PF with is wired.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what is the difference between these two PCs one thats working and one thats not working correctly with PF?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you connect the one PC that wouldn't work to the this server to see if it connects correctly there?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already done. I'm hosting a Project Zomboid server from the PC connected wirelessly. The wired PC is my personal/gaming one, and connects to the internet and the rest of my LAN just fine, and I can play on the PZ server from it. It just isn't recognized by Orbi administration tools.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the PC works if connected the RBR however doesn't work if connected to the RBS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what RBR and RBS are, but the PC that cannot port-forward (and therefore cannot host a sever) IS capable of doing everything else I care about on the network, such as accessing the internet and accessing the orbi administration page. And even though it can access the administration page, it cannot be seen on the page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR is the main Orbi router unit.
RBS is the satellite.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not tried wiring the computer to the main router. The other devices are discoverable when wired to the main router, so I would assume the computer is too, and that this is an orbi problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would make contact with NG support and let them know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would love to, but their support site doesn't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What do you mean? Whats happening?
