Orbi WiFi 7 RBE973
Reply
RBR750 Guest Wifi drops Internet
Causaelity
Reposting here per recommendation:
Hi, when using my guest network, after a period of time we appear to lose the internet (wifi remains active). We currently use the latest Firmware: V4.6.5.14_2.0.54. If I disable the guest network and turn it back on, Wifi works again. If we do nothing, internet eventually comes back. I found a similar thread on this for the RBR50 that was solved with a newer firmware, but there isn't anything newer. I tried resetting the device and setting it up from scratch again, and that did not resolve any issues.  I've tried both WPA2 and WPA3 and the issue still happens.
Thoughts?
Message 1 of 3
SW_
Prodigy
Prodigy
Re: RBR750 Guest Wifi drops Internet
If you have "Auto" for WiFi channel selection 2.4GHz, change it to static channel, pick non-congested channels for both 2.4GHz & 5GHz via NetSpot, to see if that helps.
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 534 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
