Reply
RBR750 Lagging When Downloading
tony3425
I purchased the AX4200 RBR750 a year ago from Costco.  I have run into a problem where anytime I start a download on my computer(which is hardwired into main unit), Other devices will lag, whether it be my wife who is streaming on twitch, or even my computer if I am watching something on Netflix.  Be both have brand new top of the line computers, We have 400mb internet, so I am at a loss. My Orbi has the most recent firmware downloaded, so does anyone have any suggestions, or causes for this? Thank you in advance.
Message 1 of 4
Guru
Re: RBR750 Lagging When Downloading
what firmware is on the router?
what modem/gateway is it connected to?
You have 400mbps service but is the hardwired in computer maxing out that connection when its downloading? if it is, you would expect your other devices to lag as it'd be saturating your bandwidth.
As soon as its done downloading, your lag/issues resolve?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
tony3425
Current firmware version is v4.6.5.14
The modem is Spectrum's Arris SB8200 Reb 6 Docsis 3.1
How do I know if it's maxing out the bandwidth?  Let me also add, that if my son tries downloading something on his xbox, it will do the same thing to her stream.
If these tasks are maxing out the bandwidth, are there settings within the router to prevent this? I would assume that having 400mbps speed should prevent this from happening, but I guess not?  Again, thank you for any help with this.
Message 3 of 4
Guru
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What wireless devices are you using and have connected when your downloading and streaming?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Router Mode |  Wifi Router CAX800 (Router Mode) and RBK963 (APMode) | and MK63 (Router Mode) | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, XR1000, EX7500/EX7700
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 318 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
