Orbi WiFi 7 RBE973
Reply
RBR750 addition
Sparky61
RBR750 addition
Hi i dyslexic so can someone explain in plain english I have a RBR750 with 2 satellites but I need to add another one. Is it possible, do I have to use a particular one. I used to have a RBK23 can I add one of those satellites to the 750 or must it be the same model and if so how do I do it?. Thank you kindly
Message 1 of 4
Accepted Solutions
Guru
Re: RBR750 addition
Only the following RBS can be added to a 7 series system:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Also EX and EAX series extenders can be used in a pinch.
Message 2 of 4
All Replies
Guru
Re: RBR750 addition
Message 2 of 4
Sparky61
Re: RBR750 addition
Thank you kindly 👍
Message 3 of 4
Guru
Re: RBR750 addition
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 526 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
