- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 – can’t connect can't connect to primary network, only to guest
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of a sudden my Orbi (NETGEAR AX4200 Orbi WiFi 6
High-Performance Whole Home Mesh(RBR750) wouldn't connect to the primary network. It will connect to the guest network only. Please help and I have limited knowledge on how to fix this debacle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 – can’t connect can't connect to primary network, only to guest
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
What devices are you trying to connect to the Orbi system?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
