Reply
RBR750 "Statistics" panel upload Tx rate appears bogus
gb777
Apprentice
Bought a new AX4200 router+satellite combo with firmware V3.2.15.25_1.3.15. The router is I think RBR750.
Traditional setup with WAN port connected to ISP.  When I look at the "Statistics" box linked from the "Advanced Home" page (http://192.168.1.1/start.htm) a popup opens that shows statistics over a 5s interval, shown below.
These numbers do not make any sense.  For instance, when I scp a file to an external destination (with a speed of approximately 6 Mbps), neither the "Tx B/s" nor the "Rx B/s" numbers in the WAN line budge.  What it should show is that I'm using about 6 Mbps of the WAN link.  (This is using wired Ethernet entirely, not WiFi involved).
Does the "Statistics" panel work for anyone?
System Up Time 20:20:34
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WAN1000M/Full5772484611562103341811012517:24:12
LAN11000M/Full10131664884732601873892169217:23:55
LAN21000M/Full14295162569090347794217:22:58
LAN3Link Down00000--
2.4G WLAN b/g/n/ax286.8M178628879423209476139820:20:34
5G WLAN a/n/ac/ax1201M13372221007777074061609720:20:34
WLAN Backhaul2402M0000020:20:34
Message 1 of 2
Guru
Re: RBR750 "Statistics" panel upload Tx rate appears bogus
Mnes moving. Someone is streaming video on FB as I watch mine:
System Up Time 04:01:27
WAN2500M/Full2341544994728201432093470204:00:41
LAN11000M/Full1073149524915083390456504:00:41
LAN21000M/Full908299881019014801644804:00:41
LAN31000M/Full718473617339960749378859202:04:30
LAN4Link Down00000--
2.4G WLAN b/g/n/ax1147M484598668035111404:01:27
5G WLAN a/n/ac/ax2402M1574866710740093126365204:01:27
WLAN Backhaul2402M0000004:01:27
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.3.5(Router mode/LAG Disabled) & EX7700x2
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 216 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
