- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR750 router restarting randomly
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the RBK753 with the RBR750 and two satellites. All seems to be working well except for reboots of the router that seem to happen randomly. I'll be working on something and all of a sudden my internet stops working. When I check the router it gives me the router password reset page. If I wait a few minutes the normal management page comes up and my internet starts working again. The Router is plugged into a surge protector with other devices that are not having any issues. So it is not a power issue. I can't seem to find any logs to tell me what is happening. The current firmware is V3.2.18.1_4.14. It is getting very frustrating. It just happened twice in the last hour.
On a side note, I've noticed that there are not very many WIFI settings that I can change such as beamforming even in the Advanced settings. Is that normal for this router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR750 router restarting randomly
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here. However, Orbi devices are not simple routers, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
@R0ck3tman wrote:I have the RBK753 with the RBR750 and two satellites. All seems to be working well except for reboots of the router that seem to happen randomly. I'll be working on something and all of a sudden my internet stops working. When I check the router it gives me the router password reset page. If I wait a few minutes the normal management page comes up and my internet starts working again. The Router is plugged into a surge protector with other devices that are not having any issues. So it is not a power issue. I can't seem to find any logs to tell me what is happening. The current firmware is V3.2.18.1_4.14. It is getting very frustrating. It just happened twice in the last hour.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply. The modem is my own and is a Netgear CM700. It seems to be ok when this happens as I can log in to it just fine. The home is 4900 square feet. I have the Router and one satellite on the main floor the satellite is about 30 ft from the router. But, as I stated, it doesn't seem to be the satellite disconnecting but the router is rebooting. I was hoping to get some guidance on how to get more logs from the router to determine why it is rebooting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you turn OFF the RBS, does the RBR still exhibit this problem?
Has a full factory reset and setup from scratch of the RBR and RBS and power OFF of the ISP modem been performed since last FW update?
What kind of cable are you using between the RBR and ISP modem? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't tried disconnecting the Satellite and seeing if it exhibits the problem. I'm not sure when the last firmware update was and I haven't done a full factory reset because of the hassle of logging everything back into the wifi. The cable is a cat 6 cable. and there are a couple of neighbors but not many. But, I don't think the cable, neighbors, or turning off the satellite are going to be causes of the router rebooting randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset and setup from scratch?
How was the system updated? Auto updated itself or did you apply the update thru the RBRs web page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue, started after I upgraded to the latest firmware. My setup is and RBR850 and 2 RBS850s. Any updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jhmoser15 wrote:I have the same issue, started after I upgraded to the latest firmware. My setup is and RBR850 and 2 RBS850s. Any updates?
- Mark as New
- Bookmark
- Subscribe
- Permalink
updated manually aand i did a reset afterwards still having the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jhmoser15 wrote:updated manually aand i did a reset afterwards still having the issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
i am. on fiber, and it is connected to a UBNT Edgerouter 12p
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the RBR in router or AP mode?
The Edge 12P is already a router in front of the RBR. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@R0ck3tman wrote:I haven't tried disconnecting the Satellite and seeing if it exhibits the problem. I'm not sure when the last firmware update was and I haven't done a full factory reset because of the hassle of logging everything back into the wifi. The cable is a cat 6 cable. and there are a couple of neighbors but not many. But, I don't think the cable, neighbors, or turning off the satellite are going to be causes of the router rebooting randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running in AP mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
No progress yet. I tried downgrading to 3.2.17 but it auto upgraded back to 3.2.18. Can't find a way to turn off the auto upgrade. It is still happening several times a day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, will see about getting you a beta that you should try out.
@R0ck3tman wrote:No progress yet. I tried downgrading to 3.2.17 but it auto upgraded back to 3.2.18. Can't find a way to turn off the auto upgrade. It is still happening several times a day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also having this problem and have some more information to add.
I have been having this issue since late May. I have slowly but surely replaced everything in my network setup, including the UPS it's connected to, and I even returned my Orbi routers to Costco and purchased a new set (this persisted across physical hardware).
I downgraded to V3.2.17.12_1.4.14 (if you upgrade the satellites first, and then the router, the router will not AUTO update back to the newer firmware), sadly, it still happens.
I have broken my internet down to the most basic set up, I have a FIOS G1100 router, which is in bridge mode and the orbi is acting as a router, not an AP (tho this happened when it was in BRIDGE mode with the FIOS acting as the router).
My reboots seem to happen once every other day, not many times a day, but when it happens my RBR has a white light, and the entire network goes down for about 2 minutes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi RBR750 is also rebooting seemingly randomly. Have not fully troubleshot the issue but wanted to chime in a let you all know that the issue is more prevalent.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue. Was there a resolution to this issue?
