× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
RBR750 wifi 6 issues
Mataluir
RBR750:
None of my televisions, fire sticks, or Roki support wifi 6 WPA3
Had to go to WPA2
Performance no better than the orbi ac2200 system....
Help
Message 1 of 5
Guru
Re: RBR750 wifi 6 issues
The main bottleneck in systems like these are the device you're using and not the router/satellite. If you're device aren't wireless AX you won't see much benefit. where you will see benefit is in concurrent usage. (multiple devices being used at the same time)
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 5
Mataluir
Okay, so This will still have better performance overall because it will handle a lot more devices. Is this correct?
Thanks for your prompt attention in responding to my issue.
Much appreciated.
Message 3 of 5
Guru
This is a good article to read on the downfalls and benefits of wifi 6 and how it works with current generation products.
Not a long read but educational.
Wi-Fi 6, explained: how fast it really is - The Verge
Message 4 of 5
Guru
Couple of other articles to review:
https://www.smallnetbuilder.com/wireless/wireless-features/33221-what-s-missing-from-your-wi-fi-6-ro...
Something Orbi AX doesn't have. Smiley Wink
https://www.smallnetbuilder.com/wireless/wireless-features/33229-how-much-total-throughput-can-your-...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 303 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
