Orbi WiFi 7 RBE973
RBR760 / RBS760 Firmware Version 6.3.2.4 Released
Guru
Bug Fixes:
  • Fixes Armor activation issue
  • Fixes SPC activation issue
  • Fixes attached device issue
  • Various other bug fixes
Download Link:
https://www.netgear.com/support/product/rbr760.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documenta...
NOTE: Update the RBS first, then the RBR lastly. I recommend doing a full on factory reset after the FW loads, system is back to ready and a power OFF for 1 minute then back ON has been performed. Use a wired PC and web browser for this. Load the FW on to each RBS web page using the RBS web page, not thru the RBRs web page. Then load the FW lastly on the RBRs web page. Walk thru the setup wizard. You can manually setup the system as well for those who are more experienced with this.
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satelli...
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-co...
A factory reset maybe needed if problems are encountered:
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
NOTE: The Disable Auto Update feature only prevents ANY new FW from being installed if available. This does NOT prevent the system from checking NG services to see if new FW is available. If new FW is available, this will be displayed as a notification to the user on the RBRs web page only. It will be up to the user to upgrade FW or not.
This article applies to:
RBS750 and RBS850 series satellites are NOT compatible with 760 series systems.
Please let us know how it goes in this thread...
Message 1 of 2
Guru
Re: RBR760 / RBS760 Firmware Version 6.3.2.4 Released
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 710 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
