Orbi WiFi 7 RBE973
Reply
RBR850 Anywhere access not working
tcappetti
Version: 3.2.16.22 Anywhere Access and Speedtest donot work!!
Message 1 of 6
Accepted Solutions
tcappetti
Re: RBR850 Anywhere access not working
I did the factory reset that solved all problems I had. Thanks
Message 5 of 6
All Replies
Guru
Speed test from the RBRs web page or Orbi app?
Does Ooklas installable speed test app on a PC work?
Message 2 of 6
tcappetti
Arris cable modem #SB8200
Yes, full reboot several times.
Speedtest doesnot work from Iphone 12 or the Netgear web page for my RBR850
I have the lastes updates from the web page Ver: 3.2.16.22_1.4.9
I have Spectrum  400Mbps/20Mbps
The Speedtest alone on desktop works fine.
Message 3 of 6
Guru
a factory reset and setup from scratch differs from a reboot. Press the reset button for 15 seconds on the RBR and release. Walk thru the setup wizard.
Also FYI:
https://community.netgear.com/t5/Orbi-AX/RBR850-no-access-to-interface/m-p/2014467/highlight/true#M9...
Something you may want to try with the newer version of FW if you haven't.
Message 4 of 6
tcappetti
Message 5 of 6
Guru
Thank for letting us know. Please mark your thread as solved so others will know.
Enjoy, Smiley Wink
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1666 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
