- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 Firmware V3.2.17.12_1.4.14
- Mark as New
- Bookmark
- Subscribe
- Permalink
I manually updated my RBR850 and Satellite with the 3.2.17.12 firmware and having random disconnects since. Anyone else? This is the first time I've run into issues in the 6+ months that I've used it.
RT
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 Firmware V3.2.17.12_1.4.14
Has a reset and setup from scratch been performed since update?
Is Traffic Meter enabled? If so, disable this...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply! I've rebooted, but not reset and setup from scratch. Is that really needed for every firmware upgrade? Yikes! No, the traffic meter is off (double-checked to make sure). I'm connected directly to my Verizon FIOS ONT.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sometimes yes.
Is there any router built in to the ONT or is it just a ONT only?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I'll rebuild if it keeps happening. It shouldn't be too bad.
I don't know about the ONT. I assume so as it's working without the cable router. We had Verizon make changes to the ONT years back as we weren't using the cable boxes and I purchased my own router. I didn't realize it worked without the router until I mistakenly hooked up the Orbi system, got it working, and realized the Verizon modem was sitting on the kitchen table. Oops!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well hopefully it's not needed.
Be sure to save off a backup configuration to file for safe keeping. Saves time if a reset is needed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@rtrueman wrote:Thanks for the reply! I've rebooted, but not reset and setup from scratch. Is that really needed for every firmware upgrade? Yikes! No, the traffic meter is off (double-checked to make sure). I'm connected directly to my Verizon FIOS ONT.
Out of curiosity, did you do a 'soft reboot' - use the reboot function in the app or gui - or a 'hard reboot' with the button or better yet, completely pulling the power cord for a minute?
- Mark as New
- Bookmark
- Subscribe
- Permalink
All of the above. First a soft reboot from the App using Access Anywhere. After, it appeared that the majority of traffic was on the satellite. I pulled the power on the satellite, then the router. Plugged the router back in, then the satellite and it worked well for a few hours. Another outage hit later in the day that resolved with a soft reboot from the app. So far so good.
