RickMacca's avatar
RickMacca
RBR850 Guest Network no internet
I have an RBR850 with one satellite. The RBR850 connects to the ISP modem/router through a powerline device. The internet works perfectly on all connected devices, both on RBR850 and satellite.
However, when the guest network is enabled, devices can connect to it, but do not have internet. Any advice appreciated.
Rick
  • FURRYe38's avatar
    Turn OFF the RBS.
    Does guest network devices connected at the RBR get internet services?
    What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Router build in here? IF so, Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
    Couple of options,
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
  • CrimpOn's avatar
    CrimpOn
    This sounds as if Access Control is enabled and "new" devices are not allowed.  Orbi has a curious approach to access control in that devices can perform the SSID/password handshake and be assigned an IP address, but then are denied access to the network. Does that same device that fails to get internet on the Guest network perform correctly on the primary network?
    If you bring up the Orbi web interface Attached Devices page, does it say (at the top) that Access Control is  'on' or 'off'?
    (I do not have an AX Orbi, and have come to understand that there are a number of differences between models. Maybe I am totally off in the wrong direction.)
