Reply
RBR850 / RBS850 Firmware Version 3.2.17.12
jmoyta
Tutor
RBK852 - currently at Firmware Version V3.2.16.22 (both Router & Satellite)
Checked for updates via Advanced/Administration and get "No New Firmware Available" response.
Since I see that v3.2.17.12 has been out for a few months, should I perform a Manual Update in spite of the warning to the contrary,
or is there something else I should try before doing so?
Message 1 of 4
Guru
Re: RBR850 / RBS850 Firmware Version 3.2.17.12
v12 is only availalble for manual download. NG did not make it avaialble on there update servers.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 4
jmoyta
Tutor
Do we know why they chose not to make it available through their upgrade servers?  Is this newer version not a stable release?
Message 3 of 4
Guru
NG doesn't provide details on why they don't make things avaialble. You can manually update. Manually updating is fine. Side some having DNS issues which seems to be for some, in other versions of FW, v12 is stable for the most part. If your system is working, then you can choose to keep what you have loaded currently and wait for the next version to appear.
Good luck.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 430 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
