dianneggy's avatar
dianneggy
RBR850 / RBS850 in AP mode and wired backhaul
First time post.  Setup is as follows:  ISP modem only (no ISP router) connected to Netgear BR200 wired gateway (this is not a WiFi Router).  The BR200 is set as the DHCP router and is in front of all other device connections.  I do have several unmanaged, netgear GS 108 switches.  Since the BR200 as the DHCP router, my RBR850 set to AP mode and is connected to the BR200 gateway from the RBR Internet Port to BR200 LAN port.
I have (3) RBS 850 satellites throughout home that are connected through wired backhaul (at least I think they are, as there are several unmanaged GS108 switches).  The RBS850 satellites are ethernet connected through one or more GS108 switches.  I recently updated to the most current RBR/RBS 850 firmware (Sep 2022)  4.6.9.11.  However, now I cannot seem to get the satellites to sync with the RBR850.  In addition, they do not show up in either the iPhone App or when I log directly into the RBR 850 router.
If I try to set up with a wireless backhaul (RBR 850 still in AP mode), I can see the satellites.  Alternatively, if I switch to Router Mode, I can add the satellites.  However, in wired mode, and set to AP I cannot see the satellites.
Is this an impossible setup with the BR200 Gateway and the wired backhaul?
  • FURRYe38's avatar
    Did you first sync the RBS to the RBR via wireless while in router mode, then once they were synced and front LED is BLUE, test the ethernet backhaul with the RBS connected directly to the back of the RBR, checking the RBRs web page and Orbi app for status. Needs about 5 minutes to come to ready after you connect them via ethernet.
    How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
    What CAT# lan cable are you using? CAT6 is recommended.
    https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡
    • dianneggy's avatar
      dianneggy
      Thanks for the reply.  I've tried multiple connections and do believe I tried the router mode connection with wireless sync and then ethernet.  But it makes sense for me to retry router mode to wireless connection and then ethernet to make sure the ethernet connection is working.
      Yes, there are at least two unmanaged switches between the RBR and each satellite.  RBR directly to BR200 Gateway.  Gateway wired to first unmanaged switched.  That first unmanaged switch wired to second unmanaged switch then patch cable to satellite.  And for one of the three satellites, there is a third unmanaged switch in front of the satellite.   The home is 30 years old, so when we wired it, the only way to do so was via switches.
      All wiring, including patch cables are Cat6.
