- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 WAN status
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR850 WAN status
Just switch from a Ubiquiti setup to the Orbi 6 RBR850. Gigabit Fiber connection, with a CAT6 cable going from the fiber modem to the Orbi router, but I'm only seeing 100M/Full for the WAN port status. Any suggestions?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 WAN status
Swap LAN cables between the ONT and RBR.
What happens if you connect a PC to the ONT directy. Do you see 100Mb or 1000Mb?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the reply.
I'm on the latest firmware: V3.2.16.6_1.4.4
ONT is Adtran 401.
I've tried swapping CAT6 cables between the ONT and the Orbi router, and I'm still seeing 100M/Full for the WAN port.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a power OFF of the RBR and RBS for 30 seconds since last FW update been performed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So going directly from the ONT to a gigabit switch, I'm getting 1000M. So it's not the ONT. I'm getting 100M on the Orbi WAN port going direclty to the ONT and also going to the gigabit switch.
Is there a way to force 1000M on the Orbi? Why would it be auto-negotiating 100M?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the mfr and model# of this swtich?
Sounds like the WAN port on the RBR is faulty. I would try another Orbi AX system and see if the problem continues or not. I hope not.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a Ubiquiti gigabit switch from my old setup. I am fairly certain that I have a bad WAN port on the Orbi. Going to return the thing to Amazon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help. Time to try something else. Maybe these WiFi 6 units are ready for primetime just yet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, this seems to be a isolated HW problem with your particular unit. Other users and mine are working well on the WAN port.
