Orbi WiFi 7 RBE973
Reply
RBR850 and RBS850 3.2.16.6 Connection Problems (iOS app, 10.0.0.1, and orbilogin.com)
lw187
Guide
Updated Router and two satellites to 3.2.16.6. All seemed to be ok.
Added to wired satellites today. Changed names just fine. All seemed to be ok.
At some point connectivity via the orbi app and through web browser became impossible.
Any tips from anyone? Factory reset, then download the last FW and install to revert back to happier times?
Message 1 of 5
Accepted Solutions
lw187
Guide
Re: RBR850 and RBS850 3.2.16.6 Connection Problems (iOS app, 10.0.0.1, and orbilogin.com)
Believe it or not, just turned the router off. Turned it back on. And eveyrthing visible again. Sorry for the trouble, ty for the prompt reply
Message 3 of 5
All Replies
Guru
Try a factory reset with there RBR and RBS and setup from scratch.
Do you have modem with a built in router by chance?
Message 2 of 5
lw187
Guide
Message 3 of 5
lw187
Guide
Forgot to add I'm using a Fios router as a switch only (Orib connected directly to it, as is another router)
Message 4 of 5
Guru
Ok, thanks for letting us know. Glad that was all that was needed. Will keep that in mind.
I presume your using the DMZ on the FIOS router for the RBR?
Enjoy. Smiley Wink
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 921 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
