× We are working to resolve an issue that is preventing some customers from accessing the Orbi app or web interface for the Orbi RBK85x and RBK75x. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com
Reply
RBR850 needs weekly restart
thsiao
Re: RBR850 needs weekly restart
By factory reset you mean press the button on the back for 20 seconds?
New modem is Spectrum branded model ET2251.
Message 26 of 33
Guru
15 seconds, yes...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 27 of 33
thsiao
Going to try it from scratch and not connect any satellites to see what happens now that I have a new modem. If the problem goes away, what does that mean in terms of why it gets messed up once the satellites are connected?
Message 28 of 33
Guru
Possible. If not problem with new modem and just RBR, add just 1 RBS then see.
Message 29 of 33
thsiao
I’ve come to the conclusion that my router has a hardware problem (the router is restarting, it’s not just the internet dropping). Unfortunately, my +$800 system is 14-15 months old and Netgear has decided to not do anything about this issue. Any router system should last at least 4-5 years. The fact that one of the most expensive mesh systems in the market has failed at 14-15 months should be a big concern to Netgear. I’m done with the brand and their horrible customer service.
Message 30 of 33
Guru
Have you reached to NG support. What happened?
@Blanca_O @ChristineT
Message 31 of 33
thsiao
I did, multiple times.
System is out of warranty since it is 14-15 months old. Ridiculous.
Message 32 of 33
Guru
Ok.
Message 33 of 33
Top Contributors
Discussion stats
  • 32 replies
  • 1333 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
