- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBR850 not connecting RBS750 Satellite after switching to AP Mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased my RBR850 with 2 satellites and they work great. I purchased RBS750 for my son's room and worked great until yesterday. My RBR850 router function drops the connection from the internet every 2-3 days and needed to be restarted accordingly. I replaced my router and put thr RBR850 into AP mode. The RBS750 has been synching wirelessly but now will not. I have even tried to move it about 3 feet and also have connected via wired backhaul. I have done a factory reset and the 30-30-30 reset. I am having no luck. Can anyone assist? All my other satellites are wired and work fine. Thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
SOLVED:
After updating all, I started reading a little more. I saw folks using a pfSense router which I was as well. One common denominator was making sure even though this was in AP mode, I still had to hook the WAN line from pfSense to the RBR850. Once I did this, I rebooted the RBR850 and was able to connect the RBS750 both wired and wirelessly.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBR850 not connecting RBS750 Satellite after switching to AP Mode
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Need to check to make sure the RBS750 is on same version of FW.
Can you connect the RBS750 to the back of the RBRs LAN port using a LAN cable to see if it connects?
Turn OFF the other RBS's while working with the 750 RBS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you ethernet connect the RBS to the back of the RBR, see if the the RBS gets a IP address from the RBR. If it does, try to log into the RBS web page using it's IP address in a web browser, log in maybe admin and >password< if it doesn't fully sync to the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It did not sync, I had to use the admin-->password to log in
The RBS750 is on
Router | RBR850 | RBR850 | V4.6.3.16 | No Internet |
Satellite | Orbi Satellite Russ | No Internet | ||
Satellite | RBS850 | Orbi Satellite Bedroom | V4.6.3.16 | No Internet |
Satellite | RBS850 | Orbi Satellite Kuhn | V4.6.3.16 | No Internet |
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd probably update the RBS750 first to:
The update the RBS850s:
Then update the RBR850 lastly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
All has been updated. I have tried to add the RBS750 both wired and wireless and it fails. I have also did the 30-30-30 reset on the RBS750 prior to adding it. Failed. Please advise and thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
SOLVED:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
