Orbi WiFi 7 RBE973
Reply
RBR850 not syncing w satellites after being turned off
sbernardnc
Tutor
I have an RBR850 system with 2 satellites. Firmware Version: V3.2.18.1_1.4.14,
Router is connected by ethernet to main computer.  Previously both satellites were detected and synced.   I have not changed any default settings except to rename the system using the old SSID and password which was done when purchased 9 mos ago.
This summer, I turned off the system twice while away and once while changing out the backup battery.
When  I plug in each satellite, the blue light appears for 3-4 minutes and they are detected on the orbilogin site.  I am unable to sync them and they dont show up on the orbi mobile app.  I have powered down entire system incl modem x 3, booted the router x4, reset and powered up x 2, added the satellites x 6.   I have turned off the firewall once without any effect.  Any suggestions?  Thanks.
Message 1 of 8
Guru
Re: RBR850 not syncing w satellites after being turned off
Sync the RBS using the sync button in back on the RBS then RBR.
Did this started recently?
What version of the orbi app are you using? Does this happend on different mobile devices?
Uninstall the app, reboot device then reinstall app.
Do the RBS appear on the RBRs web page?
Message 2 of 8
sbernardnc
Tutor
Hardware VersionRBR850
Firmware VersionV3.2.18.1_1.4.14
GUI Language VersionV3.0.0.51_2.1.30.3
Operation ModeRouter
LAN Port
MAC Address08:36:C9:8F:C2:91
IP Address192.168.1.1
DHCPOn
Arris, Model # TG1672G, using when first installed. No upgrades recently
Did this started recently? Yes, only after turning off system 3 times, last in late August.
What version of the orbi app are you using? Version 2.11.6.0
Does this happend on different mobile devices? Only have one phone w Orbi app--had worked seamlessly before.
Uninstall the app, reboot device then reinstall app. Done already by re-installing app and then rebooting but can try in this sequence
Do the RBS appear on the RBRs web page? Yes, appears to pair (blue light) but not will not sync
Message 3 of 8
Guru
What mode is the modem working in? Bridge or router mode? This model modem has a built in router FYI.
Possible that this maybe a Orbi app issue...
Message 4 of 8
sbernardnc
Tutor
Modem has settings that came when gotten--router.  Have never used as a router, always w NG router/access point--current ORBI is upgrade from Nighthawk that worked well for some time.  Currently one of the satellites is recognizing two devices--an ipad and my iphone, but this info doesnt show up on ORBI app as before.  Will try to remove and reboot and then re-install app.
Message 5 of 8
Guru
For future reference about your modem:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
If the Orbi app process doesnt' seem to fix this, I'd go over to the Orbi app forum and post about this there:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Maybe something going on with the app...
Message 6 of 8
sbernardnc
Tutor
I previously posted that I was unable to sync my satellites to router--RBR850.  After upgrading firmware on satellites and router, the Orbi app now shows both satellites and connections as before.  Thanks for all the suggestions.
Message 7 of 8
Guru
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
Enjoy.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 815 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
