- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS850 Backhaul Status Poor
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased an RBK852 pack a little over a year ago. Everything has been working fine until recently. I started having some odd connection issues yesterday that improved, and today, my RBS850 rebooted out of nowhere and was showing an amber status light after connecting back to the router.
I've done exhaustive troubleshooting including resetting both the router and the satellite multiple times. The satellite is reporting a poor backhaul status both in the spot it normally worked flawlessly and right beside the router.
Am I looking at some unique hardware failure?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS50 Backhaul Status Poor
Are you referring to RBS50 or RBS850?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS850 Backhaul Status Poor
Is it near the RBR or in same room while you were troubleshooting and trying to get it reconnected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, and seemingly no matter where I place it, the behavior is unchanged.
It's also not appearing to behave according to the documentation. For example... it was showing connected in the router's status page at 5G with good backhaul but a magenta status light. I could connect to its IP and browse its internal pages but the status page was showing the backhaul as 2.4G.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd make contact with NG support and get more help and information regarding this. The RBS may need to be replaced.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is this a futile effort given that I'm a year past the purchase date?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestion - I'll reach out and see what happens.
The firmware was loaded by manually downloading and applying a few weeks ago. Everything was working fine until about yesterday. I did try a manual reload on the satellite but that didn't appear to fix anything. I'll try later tonight to do that to the router as well since I can't spend a lot of time troubleshooting while working.
My SO is claiming that he's having issues with his call software even with the satellite out of the equation so I'm wondering if something is up with the router itself. He claims this problem fixed itself by plugging into the router directly... although I'm not seeing it when working wirelessly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am seeing a similar issue on just one RBS850 which is using hardware backhaul on the Cat6 link via Netgear 1 GigE Switch to the RBR850 base station. This connected to the Cable modem, which I know is working since when the system is offline I still can connect via the Wan port via Orbi app on iPhone via Connect Anywhere. Which I have used to reboot the system. Normally I need to reboot then go to that base station then un-plug it to get it operational again until it goes bad. Which you have to redo this process all over again.
It running the current most firmware. I double-checked this. I know there something wrong since It consistently this same RBS850 Satellite that goes offline.
To troubleshoot this more, I have moved it to the second 1GigE hardwired connection point 20 feet from the other location also on a clean Cat6. checked it out with one of my tools. This morning I switched out an older Netgear switch with new Netgear 2 port 10 Gig 8 port 1Gig switch. After the network went offline last night again.
What I find odd, is Orbi system will block all Network traffic on the Wireless and Wired network for both the Main Router and the working Satellite and any hard-line device. It stops routing to the internet. Again I know the network is up since I can use the Anywhere service to access the router.
I am close to running the Wifi mesh on it own VLAN and not use it as my main firewall, router, DHCP server and just have it be the Wifi services for the house.
This Seems like poor Software architecture design since the hardline network and router fuction should be running independently of Wireless and Base Station Backhaul. Now I need to decide what to do with this RBS850 since looks like it what driving the failures.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Mfr and model# of the ethernet switch in the configuration?
Does the status report Wired if you take the RBS and directly connect the RBS to the back of the RBR with out any switches in the middle?
@Gstoner wrote:I am seeing a similar issue on just one RBS850 which is using hardware backhaul on the Cat6 link via Netgear 1 GigE Switch to the RBR850 base station. This connected to the Cable modem, which I know is working since when the system is offline I still can connect via the Wan port via Orbi app on iPhone via Connect Anywhere. Which I have used to reboot the system. Normally I need to reboot then go to that base station then un-plug it to get it operational again until it goes bad. Which you have to redo this process all over again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The issue is not the Switch, since again I have a second Satellite that does not see the same issue it is further from the router. Also tried two network switches
The old I was running since last night, Netgear GS116E and the new one Netgear GS110 MX
Note I have changed the network cable connecting the Satelite to the ethernet port, back haul hardpoint port aka different location, the switch they connect to.
The firmware version is 3.2.18.1_14.14 on the RBR850 and on the RBS850 3.2.18.1
It more likely a thermal event, memory corruption or state getting getting corrupt on the Satilite that fixes itself on shutdown and reboot, then overtime happens again. It is repeatable in this unit.
I work for a large semiconductor company, currently on a number of large scale supercomputers with much more complex networking foundations during the day. Which why I just want this to work at night so my kids and Wife do not **bleep** me out for it not working ; )
I had to do fault isolation first, to the unit itself, remove the other variables from above. Note it been going on over a few firmware versions, I always have to reboot the Orbi they, power cycle each satellite post power cycling the router to get the system stable until the next failure happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does the status report Wired if you take the RBS and directly connect the RBS to the back of the RBR with out any switches in the middle? Make sure the RBS works here first and reports correctly.
Try swapping RBS around to see if the problem follows. If it does and direct connection with 1 RBS still doesnt' work right, possible faulty RBS...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Already did that, again as I said even put that RBS on a new network port this was a week ago and still failing regularly. I have a stable network right now so I can work type this post. They have QOS issue when backhaul sync fails, which cascades to the router fuction also failing for both wired and wireless connections. I am sure if I put this in AP mode and put firewall/router on the system hardline would work un-interrupted upon backhaul failure, then just my Wifi would go down.
Right now I am looking at the following two options replace RBR at full retail since it now out of warranty or put in a hardline only Firewall/Router. If the system does not stay stable.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, it has a connection with Switch in the middle, the switch in the middle is not the issue. The Log output could be improved for debugging.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you did connect the RBS directly to the RBR with no switch in the middle and the problem followed?
I would presume if so, the RBS would be fautly, not the RBR.
Be aware that some switches with "Green Ethernet" may not work well with Orbi systems. I don't use these and thus don't encounter problems with wired RBS.
If the RBS IS failing to connect fully or show WIRED when directly connected to the RBR, then contact NG support and ask about what your options are.
There is a beta you can try as well though not sure if this would fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes the RBS looks to be the issue. I am going to put a network sniffer on the network next time the RBS fails to see if can see something strange. HW Router/Firewall would be to isolate wireless network so if it failed the main hardwired network would still operate. my Office PC's Game Consoles, AppleTV's, Stereos, and 3 TV's are all on hardlines, so they would not be interrupted if a failure happens on the Orbi network.
The Switch is not a green power one. I do not like to use those as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both model switchs you listed have Green Ethernet...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Put the Orbi RBR850 into AP mode things are more stable, had Airport Extreme in the closet so I could set it up as the router for now. I think there is a lot more going on than a switch issue. Looking through the threads it happens way too offten and across generations of products.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Check stability with out your switches first. Again, some switches don't work well with Orbi, especially Green Ethernet featured ones. The ones you listed have this. Check the spec sheets.
IF the RBS work with out the switches in the middle, then this isnt' a Orbi issue.
If the problem follows the RBS with or with out the switch, then the RBS maybe just faulty. Try a full re-load of FW on the RBS, factory reset the RBS, remove the prior connection from the RBR and re-synce the RBS FIRST wirelessly to the RBR, then connect the RBS wired to the RBR directly or thru your switch.
NG GS-105/108v4, D-Link DGS-105/108 and HP ProCurve 1400/1800 series switches work well for Orbi systems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this since you posted last?
@jmcvey90 wrote:Thanks for the suggestion - I'll reach out and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Might try a factory reset on the RBR and setup from scratch for router mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You might contact NG support and see what your options are. You may have a faulty system that needs to be replaced.
