Reply
RBS850 Compatible Satellite model options
rdt40ish
I have the RBS850 router +1 satelite option.  i need to get another satelite.  can i use other models or do i have to same model satelite?
easy question i presume but didnt find my answer "yet" in the forum.
Message 1 of 3
Guru
Re: RBS850 Compatible Satellite model options
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
You can use RBS7 or 8 series RBS. You can use EX or EAX series extenders as well.
Thank you.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 3
Guru
RBS750 or 850 will work. Also EX7500,7700, 8000 AND EAX80 extenders will work as well with Orbi systems.
Testing
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 178 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
